Optical illusion sends incoming pilots on a spin
Forum for discussing non-Pakistani aviation issues and news.
pk363
Post by pk363 »
CHENNAI: As a Saudia Airlines flight approached Chennai airport to land at the Pallavaram-end of the runway, the pilot spotted, from the air, the wing tip of another aircraft waiting on the taxiway too close to the edge of the runway. The pilot decided not to land and did a go around.
Checks revealed that the aircraft on taxiway Kilo was stopped on the runway holding point marking, and that its wing tip was not too close to the main runway. It was an optical illusion that made the Saudi Airlines pilot think so.
Two more such incidents happened in the last couple of months when pilots of foreign airlines reported runway incursion by flights waiting on the taxiway which connects to the Pallavaram-end of the runway.
Aircraft cleared for take-off from this end of the main runway wait at a holding point on taxiway Kilo if there is an incoming flight approaching to land. The taxiway joins the main runway at an angle. Hence, the wing tip of aircraft on the holding point appear to be close to the edge of the main runway.
Sources said that wide-bodied aircraft, such as B777, have a wider wingspan. If such an aircraft is on the runway holding point of Kilo, then the pilot flying in to land on the runway gets an impression that the wing tip of the stationary plane is too close to the main runway.
"We have drawn the runway holding point marking as per the International Civil Aviation Organisation (ICAO) norms. The marking has been in use all along," AAI officials said.
An airline official said the runway holding point marking made as per ICAO regulation does not appear to be sufficient. They should have made the marking well before the point where it is currently marked so that aircraft do not stand too close to the mouth of the taxiway. "This will eliminate the illusion," the official said.
Airports Authority of India officials are surprised that pilots are getting the impression suddenly because such a situation was never reported before even though the runway and the taxiway have been in use for several years. They are considering the option of redrawing the runway holding point marking to prevent such incidents from repeating.
"Mostly foreign pilots who are not familiar with the airport terrain get the feeling. We have never got the impression," said a Jet Airways pilot.
Former pilot and air safety expert Captain A Ranganathan said that the "runway holding point markings are correct. It must be only be an illusion." Airport director E P Hareendranathan said that, "We are assessing the issue after we received a report that an aircraft had to go around."
http://timesofindia.indiatimes.com/city ... 120077.cms
