airblue Airbus A320/A321 Flies to Sharjah for Maintenance Checks
On August 28, airblue Airbus A320 (aircraft registration AP-EDH) apparently was ferried from Karachi to Sharjah as flight PA9005.
Seems, the aircraft underwent maintenance checks performed by Air Arabia Engineering facility at Sharjah Airport and appeared with Air Arabia IATA code 'G9' on the ground on August 31.
On September 1, the aircraft was ferried from Sharjah to Lahore as flight PA9006.
Re: airblue Airbus A320/A321 Flies to Sharjah for Maintenance Checks
On September 20, airblue Airbus A321 (aircraft registration AP-BMW) apparently was ferried from Karachi to Sharjah as flight PA9013.
Probably for maintenance checks in Sharjah? The aircraft is still in Sharjah.
On September 27, airblue Airbus A321 (aircraft registration AP-BMW) arrived in Lahore at 11:15 PM as ferry flight PA9014 from Sharjah.
Source: lahoreairport.com.pk
Later, AP-BMW departed from Lahore on September 28 at 12:47 AM as airline's commercial flight PA412 to Sharjah.
adamalikhan
Post by adamalikhan »
Did Airblue not have agreement with Turkish Technic for all their maintenance and checks on aircrafts? Unless it has expired.
airblue also has an agreement with Switzerland's SR Technics. The agreement runs until 2022 and covers the maintenance and overhaul of the CFM56-5B engines used on Airblue’s Airbus A320 fleet.
airblue Airbus A320 (aircraft registration AP-EDG) photographed in Zurich in May 2018.
ImageAirBlue - Airbus A320-200SL - AP-EDG - Zurich Airport by Mike Wyss, on Flickr
rayyanullah
Post by rayyanullah »
A nuclear state having routine maintenance of their planes performed in Sharjah
Need more be said?
On February 20, airblue Airbus A321-200 registration AP-BMO was ferried from Lahore to Sharjah as flight PA9001 probably for maintenance checks.
Probably, airblue Airbus A321 registration AP-BMN undergoing maintenance checks in Sharjah where it arrived as flight PA212 from Islamabad on October 13 and is inactive since then.
https://www.flightradar24.com/data/aircraft/ap-bmn
Abbas Ali wrote: Sun Feb 21, 2021 1:23 pm On February 20, airblue Airbus A321-200 registration AP-BMO was ferried from Lahore to Sharjah as flight PA9001 probably for maintenance checks.
the flight trajectory is not showing the blue magenta color, most probably the flight remain below FL300 throughout the endurance of flight :-k
On October 22, airblue Airbus A321 registration AP-BMN returned to service and arrived in Islamabad as flight PA261 from Ras Al Khaimah.
On July 2, airblue Airbus A321 aircraft registration AP-BMM arrived in Sharjah as ferry flight PA9001 from Islamabad completed in 4 hours & 27 minutes. Strangely, for some reason, maximum altitude gained by the aircraft was 10,550 feet. Maybe due to some technical issue the aircraft did not fly at higher altitude.
On July 6, airblue Airbus A321 aircraft registration AP-BMM arrived in Islamabad as ferry flight PA9002 from Sharjah completed in 2 hours & 52 minutes. Maximum altitude gained by the aircraft was 39,025 feet.
