Pakistan Navy Inducts Embraer Lineage 1000 Long Range Maritime Patrol (LRMP) Twinjet Aircraft
Guru
Re: Pakistan Navy Planning to Acquire Twinjet Aircraft
Post by Guru »
Reportedly, these aircraft are being inducted as a replacement of P3C Orions which are to be retired.
Inam855
Post by Inam855 »
SM wrote: Fri May 28, 2021 7:09 pm Even people inside PIA know that PIA isn't worth skipping "to captains directly" or even getting a job at all.
An airline whose flight crew can intentionally crash a fully serviceable, modern airliner in perfect weather conditions should at best be ashamed.
Every pilot in PIA who could leave has left and those that are left are trying hard to - although incompetence or luck are preventing them from jumping to foreign carriers.
SM, while you do make very valid points in your posts and there is absolutely no denying that PIA's personnel standards have slipped, lets not pretend this exact scheme wasn't hatched and executed by a group looking for a second chance at life. Like A320 said, their spectacular performance in training where all but one failed and then the last one was dismissed due to serious CRM/HF issues are enough to get the point across. Sadly, the intervention of "superior beings" repeatedly behind promotions/command upgrades in PIA is relevant to the late capt and both sisters with questionable performance observations.
A310, while we dont necessarily see the same on many things, I have to partially side with you on this one.
Coming back to topic, I am sure this hefty fleet of 11 is surely required including a decked a VIP transport larger than the one assigned to the prime minister/president/COAS. I am also sure that it is imperative to national security to have the VIP transport with a bed and pressure padded seats delivered before any surveillance/defense activities aircraft. For lumber 1 training ofcourse.
Turboprop, hypothetically, do you think a few years later someone will magically discover these ERJs arent fit to serve the intended purpose, they will be auctioned off for cents on the dollar and next day Bahria Town airlines will be born?
Like on other aircraft operated by Pakistan Navy, "Hasbunallahu Wa Ni’mal Wakeel" meaning "Allah (Alone) is Sufficient for us, and He is the Best Disposer of affairs (for us)" also painted on Lineage nose section.
June 4 photo taken at PAF Base Nur Khan, Chaklala, Rawalpindi: https://www.jetphotos.com/photo/10179238
Salman Haider
Post by Salman Haider »
PAF Falcons - Second to None
www.paffalcons.com
Ceremony held at Pakistan Navy PNS Mehran Naval Air Station, Karachi, for formal induction of twinjet Embraer Lineage 1000 as Long Range Maritime Patrol (LRMP) jet aircraft in Pakistan Naval Air Arm.
Pakistan Navy intends to add two more Embraer aircraft.
Re: Pakistan Navy Inducts Embraer Lineage 1000 Long Range Maritime Patrol (LRMP) Twinjet Aircraft
May be the LRMP conversion will take place subsequently. No external antennae etc seen nor is the livery suitable for intended role.
lets see.
Pakistan has hired Italian defense company Leonardo to convert three Embraer Lineage 1000 regional jetliners into long-range maritime patrol aircraft for Pakistan Navy.
The contract includes design, modification, installation and integration of an anti-submarine warfare and maritime patrol package. The three planes will then be introduced into service as "Sea Sultan" patrol aircraft.
Follow-on contracts are expected to bring the total number of Sea Sultans to 10 as replacement of Pakistan Navy P-3C Orion fleet.
Under an additional contract, South Africa’s Paramount Group will handle the pre-conversion maintenance, repair and overhaul of these Embraer aircraft.
Info source: https://www.defensenews.com/industry/20 ... n-program/
Salman Haider
www.paffalcons.com
Pakistan Navy to induct two more Embraer Lineage 1000 for modification into Long Range Maritime Patrol (LRMP) "Sea Sultan" aircraft. The two aircraft are probably construction numbers 19000296 built in year 2010 and 19000362 built in year 2014.
ImageA6-HHS Embraer EMB-190BJ Lineage by Robert Camp, on Flickr
ImageM-AKKU Embraer EMB-190BJ Lineage by Robert Camp, on Flickr
Embraer Lineage 1000 construction number 19000453 built in year 2011 is already in Pakistan Navy inventory since year 2021.
