Lahore Airport Expansion Project
Re: Lahore Airport Expansion Approved
Post by Abbas Ali » Mon Mar 09, 2015 2:13 pm
According to information in Pakistan Civil Aviation Authority (CAA) supplement in today's (March 9) newspapers:
International wing of Lahore Airport will be expanded over 30,000 square meters to ensure more than 3.8 million passenger handling capacity per annum.
Post by Abbas Ali » Thu Mar 19, 2015 11:42 am
In today's (March 19) newspaper.
Pre-Qualification of Contractors
Construction/Expansion of Lounges at Allama Iqbal International Air Port (AIIAP) - Lahore
Pakistan Civil Aviation Authority (CAA) has planned to undertake the subject works in order to improve, expand and renovate the existing lounges at Allama Iqbal International Air Port (AIIAP), Lahore, for convenience of passengers.
The components of the works shall consist of, but not limited to the following:
* Extension of terminal building of approximate 40,000 square meters including all civil and Electrical & Mechanical (E&M) works.
* Two boarding bridges.
* Baggage claim system.
* Elevators/escalators.
* Visual Docking Guidance Systems (VDGS).
* Flight Information Display System (FIDS), Public Address (PA) and Master Clock System.
* Closed-circuit television (CCTV) system.
* Check-in, immigration custom counters and lounges furniture.
* Landside development, including car park for 600 cars, utilities, Heating, Ventilation and Air Conditioning (HVAC) plant room, electrical room, water storage tanks and link road.
The applicants must keep under consideration that the proposed work is required to be executed in restricted and operational area of the airport with utmost care and quality (international standards) without disturbing flight operations and passenger movement.
Post by Abbas Ali » Thu Mar 19, 2015 11:45 am
Presently Lahore Airport terminal building has seven jet bridges and with addition of two jet bridges the total number of jet brides will increase to nine.
I think older seven jet bridges will be replaced with new design bridges when two new jet bridges get added with extended terminal building.
Other possibility is that two jet bridges, one from each end of terminal building, will be moved to extended part of the terminal building in case it's extended from both ends and in that case total number of jet bridges will remain seven.
Seven jet bridges of Lahore Airport.
Post by Abbas Ali » Fri Mar 20, 2015 3:47 pm
Prime Minister Nawaz Sharif in a ceremony held in Islamabad today said that under his government in late 1990s a bigger terminal building was planned for Lahore Airport. However, after the end of his government, the military government changed that plan and built smaller terminal building that experiences problems in handling three or more than three international flights at a time, he said.
Prime Minister suggested said that the existing terminal building should be expanded from its both sides/ends and a separate smaller terminal building should be constructed to handle domestic flights.
Post by Abbas Ali » Thu May 14, 2015 1:11 pm
According to report in today's (May 14) "City42" newspaper, Lahore Airport expansion project will be completed in two years. The extended terminal building will use Mughal style of architecture of existing terminal building. The extended terminal building will also have jet bridges.
Re: Lahore Airport Expansion Project
Post by Abbas Ali » Mon Jun 08, 2015 11:42 am
Prime Minister Nawaz Sharif visited Lahore Airport today where he was briefed on airport expansion plan and steps being taken to improve facilities given to the passengers.
Omairi7
Post by Omairi7 » Mon Jun 08, 2015 12:45 pm
I heard about the actual design which was approved for lahore inernational airport. There were 12 bridges, 2 active runways, and airport was equivallent to Karachi airport. Blv me there was no sign of askari 10 society ;) too but as soon as govt was changed every plan went to scrap and now we are left with only tiny airport...
EK, EY, SV, PK, AIR BLUE, EASY JET, AA, TG, MH, FLY BE, VUELING, SAS, SWISS, LH, BA, AIR BERLIN, RYAN AIR, GERMAN WINGS, JET BLUE, U.A, QATAR , AZAL ...
Omairi7
Post by Omairi7 » Mon Jun 08, 2015 12:52 pm
By the way when will they starts working on Expansion plan of Lahore international airport...???
Post by Abbas Ali » Mon Jun 08, 2015 3:41 pm
PTV News did not provide Lahore Airport expansion project details.
According to the news channel, Prime Minister Nawaz Sharif wants expanded Lahore Airport terminal building to meet passenger/air traffic growth needs for next ten to fifteen years.
Meeting chaired by Prime Minister Nawaz Sharif to discuss Lahore Airport expansion project.
Prime Minister Nawaz Sharif accompanied by other officials at Lahore Airport.
Post by Abbas Ali » Mon Jun 08, 2015 7:47 pm
Prime Minster Nawaz Sharif has approved Lahore Airport expansion plan, according to Geo News.
Post by Abbas Ali » Mon Jun 08, 2015 10:36 pm
Seems following two options were discussed in meeting chaired by the prime minister today.
Option A - Expansion/extension of existing terminal building.
Option B - Construction of New Domestic Terminal building for domestic flights.
Artist's impression of a new domestic terminal building with four jet bridges under Option B of Lahore Airport expansion project.
Demerits of new domestic terminal building (Option B) - Site 2 include:
Parameters - Option B - Site 2 Across the Runway
Road Network
Land acquisition required (5 acres) for access.
Operational Risks
Towing of aircraft through two active runways.
Airport Operations
Split operations on both sides of the runway resulting in inconvenience of passengers.
Apron
Required.
Probably prime minister approved Option A i.e. expansion/extension of existing terminal building.
hassan khan
Post by hassan khan » Tue Jun 09, 2015 12:12 am
Option B, could be made realistic by linking the international terminal with the domestic.terminal through an underground section, instead of transporting passengers from buses and having to.cross the runway.
Or if they want to expand the existing facility, I think they should relocate the SAPS office that is right next to the terminal building, which would allow them decent space to expand the building.
Btw, a little off topic but does anyone know what the basement that is visible as you enter lhe airport through the parking, is for? Could that be utilised to create more space?
boeing787
Post by boeing787 » Tue Jun 09, 2015 1:14 am
Omairi7 wrote:I heard about the actual design which was approved for lahore inernational airport. There were 12 bridges, 2 active runways, and airport was equivallent to Karachi airport. Blv me there was no sign of askari 10 society ;) too but as soon as govt was changed every plan went to scrap and now we are left with only tiny airport...
WHEN?
Student of Economics. My brother works for Air Canada.
Omairi7
Post by Omairi7 » Tue Jun 09, 2015 11:41 am
This was planned in the govt tenure before the govt was sacked by Military.....old stuff.
But things are changed now.. heard so many times that Lhe airport extension planned but never saw an inch moved. Infect runway upgradation and Cat 3b is also pending due to housing population near airport which is increased.
Post by Abbas Ali » Tue Jun 09, 2015 2:25 pm
Somewhere I read that original terminal building design also included Mughal style white marble domes that were withdrawn from finally approved design as a cost-cutting measure.
Don't know whether it's true or not but I also heard that in the original design for people coming from areas like cantonment, gulberg, upper & lower mall etc. there was a short route underground access road crossing runways, apron, terminal building before emerging in the car park. The underground road was not opened or completed for general public use for security reasons. The closed entry/exit point for that underground road can be seen in airport's car park.
